Higher Capacity Battery upgrade
Can I install the same higher capacity battery from the mid-2013 (13") MacBook Air, in a mid-2011 (13") MacBook Air?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
That's not going to signifcantly change anything it's the more efficient processor and architecture -- which result in significantly improved battery life -- not the battery alone. This happened the last time "significant battery life increase" was announced... hypertheading and other improvements contributed significantly to battery life.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
I agree, it's not worth replacing a working battery set for the little gain a few Ah the newer battery offers.
Hi, I have the MBA mid 2011 too and I have to replace my battery since I have a battery health of only 60%. The battery for the 2011 model is out of stock. Now I'd like to know if I can install the battery of the mid-2013 model.
If the part numbers match, they'll fit. The parts catalogue indicates it wont.
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 4,872
2 件のコメント
Is your current battery worn out?
Dan さんによる
@Dan, No. I'm just interested in the longer battery life.
jeffcs さんによる
