メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
4S reboots automatically after shutdown (not while plugged to pc)
Hello everybody!
I have a 4s 32gb with this problem: when I turn it off (holding on-off and sliding on "turn off"), it reboots itself immediately after.
The problem doesn't occur when the iPhone is connected to the pc. Why?
I've already tried to replace the battery, but the problem persists. I've also tried to reinitialize in DFU mode, withouts results. Do you know what it can be? Battery connector, charging connector, on-off button....?
Thanks
Teo
ITALY
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
i have the same problem, nothing suggested online worked.
my phone worked fine before i upgradet to IOS7.x.x which sugests the problem is a software bug, and not hardware related ( unless the hardware got faulty during the software upgrade, which is dobtfull )
I think apple put this issue on the code on pourpose to force people to buy iphone 5's
さんによる
Nuno, same thing happened to me right after the update AND my battery runs low faster than it used to...
さんによる
I have the same thing problem … Uhmm … Yesterday i wemt to repair shop to change the Battery then after that . It started to automatically rebooting my iphone4s .. i tried your suggestions and comments but .. still it reboot itself Either Connected or Not Connected to charger … please help me :( im frustrated about this..
さんによる
コメントを追加
3件の回答
ベストアンサー
open you iPhone and test it. unplug the power cable first. turn off device and check. if its still reboots, unplug the dock connector and check again....
have a nice repair
iPhone 4S ドックコネクタの交換
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
Sorry iwillfix, what do you mean with "test it"?
I have to:
1 - unplug the cable
2 - turn off the device and check if it reboots again
Those 2 points I've already done.
Then you said to unplug the dock connector and re-check again in the same way?
Sorry for my english, I'm italian =)
さんによる
so did the device still booted up by itself when the power button cable was disconnected? yes? cable ok.
now do the same thing with the dock connector.
turn off phone, open and disconnect dock connector cable, turn device on and back off again to look if it boots by itself
btw your english pretty good ;-p
さんによる
Ok, I've disconnected the dock connector: after shutting down the device it doesn't reboot itself.
I only hope that it's a problem on the dock connector and not on the "mobo"...yyyyyap! XP
さんによる
replace the dock connector and you will be fine :-)
さんによる
DONE! Thx a lot, iwillfix! ;-)
This is a great website!
さんによる
1以上のコメントを表示
コメントを追加
My 4S did the same thing. I took it Apple and was told to buy a new phone. Another post on this site suggested cleaning the docking connector with isopropyl alcohol. I carefully did it with a tooth brush and IT FIXED IT!!!
THANKS
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The toothbrush solution don't work for me.
I open the phone and disconnect the battery connector and wait for a couple of minutes and after connect and turn phone on.
No more sound and reboot problem on my 4s...for now...
さんによる
コメントを追加
I shut down using the two bottoms at the same time.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Teo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 11,193
