メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
MacBook 5.1 temperature sensor missing?
Picked up a Macbook to fix the other day and started to clean the internals as they were very dusty. Cleaning around the heatsink and noticed a connector on the board without any cable connected labelled "temp".
No obvious cable anywhere to connect and cant find anything relating to it in any disassembly guides.
Im guessing there was one there and needed but not 100% sure.
can anyone help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
On the early 2009 MacBook 820-2496-A logic board, the J5520 connects the CPU/MCP Thermal Sensor. It looks like this one http://www.ebay.com/itm/Apple-MacBook-A1...
さんによる
コメントを追加
1 件の回答
ベストアンサー
I don't think there is a sensor on all models... you gave a very generic model description (there's 5 builds in that series) but from this picture sequence for the fan replacement it doesn't appear to me that anything was attached to that connector block.
If this answer was helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
kelvin stephenson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 1,173
