メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Tickle Me Elmoは、子供向けテレビ番組『セサミストリート』のキャラクターであるエルモをモチーフにした、Tyco-Preschool社製の子供用おもちゃです。1996年に米国で発売されました。
New batteries, doesn't work.
He was working. Changed the batteries and now he doesn't. Am I missing something here? Is there anything I can try?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
8 件のコメント
When was the last time Elmo worked? You checked the batteries, the proper position and checked for corrosion on the battery contacts?
さんによる
I fond a plastic bag in the foot of mine why is it there
さんによる
I have a 20 year old Elmo the shaker box stopped working, how do I get a new one.
さんによる
hey there do you still have the shaker box?
さんによる
Mine also does not work after replacing batteries....plz tell me where to get another shaker box
さんによる
3件以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
Did you replace ALL the batteries?
Instructions
Open the door to the battery compartments on the bottom of Elmo's feet with a Phillips head screwdriver. Remove the old batteries.
2
Place the AA batteries in the battery compartments according to the polarity indicators designated by a (+) and (-) sign.
3
Replace the battery compartment covers. Replace the screws. Set the "On/off" switch on the bottom of Elmo's right foot to "On."
4
Slide the back cover off the activation box. Install the two AAA batteries in the compartment. Place the batteries in the compartment according to the polarity indicators inside the case.
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
do I mash anything to make it start after batteries
さんによる
Where is "the back cover off the activation box"? and how do I access it?
Thank you.
Mike D
さんによる
Mike, it's on the back. See the diagram here: Where is Location of Elmo's Activation Box Cover?
さんによる
I replaced the battery, not working.
さんによる
Mine was working fine put in box.....when I took it out put new batteries just wont turn on....tried everything??
さんによる
3件以上のコメントを表示
コメントを追加
I put new batteries the bottom of the feet and still will not work
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I can not get my tickel me Elmo to work after installing new batteries.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jean さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 66
今までの合計 16,891
