メインコンテンツにスキップ
モデル番号A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5もしくは 3.4 GHz Core i7 Processor, ID iMac12,2
708回答 すべてを表示
締切られた回答
Change iMac 27" mid 2010 Graphics Card
Hello guys,
I have an iMac 12,2 27" mid 2010, Intel i5, 8GB RAM and AMD RADEON HD 6770M(512MB).
I would like to know if it is possible to change the graphics card of this specific model to maybe an NVIDIA GeForce GTX 660 Ti | GeForce? Or does it have to be an ATI?
I've been seeing alot of tutorials around for changing the graphics card but none for my specific model.
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Can you supply the last four digits of your serial number as you have conflicting information on what your system is. The 12,2 model is a mid '11 model not a mid '10.
さんによる
Identity taken from serial number:
Apple iMac "Core i5" 2.7 27-Inch (Mid-2011) Specs
Identifiers: Mid-2011 - MC813LL/A - iMac12,2 - A1312 - 2429
さんによる
Mayer, does this mean that it can be modified or not?
Thanks for the reply
さんによる
コメントを追加
2件の回答
ベストアンサー
Because, not every model of iMac can have it's graphics card changed. that's why a firm and proper ID of which Machine you have is the starting point. Due to Firmware/Software updates you'd want to stick with an OEM or an "optional" OEM card, if indeed, it can be replaced.
Remember to return and mark accepted the answer that best solves your problem.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hey guys, sorry for the misinformation, you are indeed correct, its mid 2011. I couldn't locate the serial number on the rear of the iMac nor underneath it. Instead, here is a screenshot of the system information
http://i.imgur.com/9yvQhTj.png
Thanks for the help!
さんによる
You might be able to upgrade to a 1 GB Radeon HD 6970M (a faster OEM card with more RAM)- if so this would be a very advanced DIY (basically tearing almost everything out of the machine, swapping the card, then reassembling). Though technically possible it might not be economically feasible... you'd be smarter IMHO selling this unit, ''take the proceeds along with what you'd have spent on a new graphics card to purchase a MacPRO//which is a much more user upgradeable machine.
さんによる
コメントを追加
LiquidIce, I just looked at your screen shot and it seems Apple has opted to replace the mid 2011 Graphics Card in imacs with the last four of their serial that matches yours. Do a quick search and you should be in business. As for me with a mid 2010 with the same issue, I am out of luck, Urgh...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 15,547
