メインコンテンツにスキップ
GSM iPad 2は16、32、64GBの容量オプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1396。修理作業は複雑で、ヒート(熱)を当ててこじ開ける作業が必須です。
20回答 すべてを表示
Back cover of iPad "Wifi only" usable?
Hello,
Here is the story: The back plate of an iPad 2 Wifi & 3G needs to be replaced. Unfortunately, I was given a "Wifi only" back plate rather than a "Wifi & 3G" one.
Although there was a SIM Card in the slot, the owner of the iPad told me that he doesn't need or work via the SIM Card but via Wifi only.
I was wondering if it is possible to use this new back plate at all. Can I just fix the card unit with adhesive tape (there are no holes, of course, for it)?
This is my first repair of an iPad, so I would appreciate any input.
Steffen
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Without a plastic back the G3 cellar services won't work. Best to get the correct case assembly.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi Dan,
Thank you for your response.
Yes, you are right. I compared both back plates with one another and found additional physical differences. They are different types after all.
Steffen
さんによる
コメントを追加
It should fit. Do not install SIM card tray and the top antennas, everything else stays the same
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
The cellar network antenna will be missing and it needs a non metal cover to access the net. <Bottom line won't work>
さんによる
Hi Dan, Steffen said the owner doesn't need cellular functions. So it is possible to work, without cellular forever.
Still, I recommend selling the back plate to someone who really needs it, Steffen.
さんによる
What if he sells it? I don't like removing major features like this. Remember the system still thinks it has G3 services as well.
さんによる
The system will display " NO SIM" on the top, since you didn't even put a SIM card slot. Also GPS will not work because it has no top antennas. Otherwise it's just like an iPad wifi only.
さんによる
Hi Tom and Dan, thank you for your comments. I compared the two plates again, and it seems that I could actually use the back plate of the "Wifi only". However and as you both indicated, in this case the G3 antennas don't fit and needed to be removed. Nobody would notice (i.e. see) this difference. The good news is: I was able to "convince" the owner that a proper plate would be the "better" way. So, I will get the right back plate after all. In any case, Thank You!
さんによる
コメントを追加
回答を追加する
Steffen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 496
