メインコンテンツにスキップ
Model M7572 / 400 or 500 MHz G3 processor
Why is my G3 PowerBook not starting?
I have a G3 Firewire Powerbook that I purchased a while ago and upgraded from 400 to 500 MHz processor with 512 Mb RAM. It is a still a workhorse after many years. Recently, the computer crashed after starting up when I was about to open the Safari browser application. The screen shut down but there is still power since the lock key lights came on when pressed. The battery is brand new and has full power. I swapped out the 500 MHz processor and replaced with the old 400 MHz. It worked and computer started up wonderfully. However, after I opened the browser application, the computer crashed again. Now both processors won't work. I tried to unplug the PRAM battery and nothing works. All the softwares have been running fine before and are fully updated. What is causing the processor to fail? Bad RAM or logic board? Thank you for your help and would appreciate any helpful advice.
Gotten Stuck
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Very odd ...
At first I would think the OS and/or the apps have a corruption. But that doesn't explain the CPU dyeing.
Do you have another Mac system to run Disk Utility from? So you can check out the HD.
Did you use proper ESD practices and use fresh thermo grease on the heat sink? That could explain the CPU dyeing.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
David Chang さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 199
