メインコンテンツにスキップ
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418回答 すべてを表示
Dark Screen not fixed - Changed Inverter and LCD Panel. What Next?
Hello everyone. I am trying to fix up a 2.0 Ghz 2006 MacBook for my mum to use. About one year ago the screen went dark, you can still see its working under a flashlight but the MBs backlight is not working.
I bought an MBP so have not tried to fix it until now....I have changed the inverter and the screen (at great expense) and its still not working!! what shall i do next??
please help
g
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
After changing the display can you see it is working when lit with a flashlight ?
Yes : the backlight still isn't working.
What do you know about the exchanged parts ? Brand new or used ? Even new parts can not always be trusted to be all right. So it still could be the inverter, or the lamps in the display panel.
When these parts are brand new and tested, check the inverter supply (mostly 12VDC) voltage. Maybe there is a fuse on the power supply which has blown. Also check the low voltage wiring to the inverter. There can be a short circuit in the high voltage wires to the backlight lamps, causing the fuse on the new inverter to blow instantly. SMD fuses can be recognized by the desription on the PCB (F1 e.g.), and can easily be tested with a multimeter, and replaced by a glass fuse by soldering wores to it.
Then there is the baklight control voltage (mostly a PWM signal) coming from the motherboard to the inverter (sometimes passes the power supply PCB). It controls the brightness of the backlight and could be missing or too low. Then mostly there is a Backlight_ON/Inverter_ON signal which could be the cause.
The backlight lamps can not be tested with a multimeter (infinite resistance), and they normally break only because of over-aging (or by heavy mechanical shock).
When you can't see anything with a flashlight on the new TFT panel, it could be broken (even though it is new). Try testing the old TFT to see if that one is still displaying something (maybe by connecting the new TFT you broke the video card).
Please let me know about your own diagnosis and remedy.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
very good explanation = +
さんによる
コメントを追加
The last piece to replace in the display would be the inverter cable. This can also cause no backlight.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
hi guys thank you both very much for your advice...
I m slightly embarrassed to admit that I have solved the problem simply by disconnecting the inverter cable from the logic board, blowing into it and then replacing it...! it was an extremely technical process :)
In my defence I had tried this once already without success..
Anyway it works now, but I am faced with the task of trying to return an expensive LCD panel to someone who doesn't really want it back..
Thanks again for your advice,
gt
さんによる
コメントを追加
回答を追加する
Graham Taylor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 7,569
