メインコンテンツにスキップ
iPad Miniは7.9 インチのディスプレイで、容量は16、32、64 GBがあります。
630回答 すべてを表示
iPad Mini touch replacement went really really bad.
I changed an iPad mini touchscreen, not first time doing this.
Well the thing is that everything went to s#!t.
My standby wake button doesn't work.
My touchscreen stopped working. i even tested another touchscreen with the little connector board already soldered and didnt worked either. Then i tested both touchscreens and worked properly on a different iPad Mini.
The battery is at 78% and im getting the full charged icon.
It is restarting itself every 5 to 10 minutes.
I was able to perform a restore via itunes, but the issues persists.
I disconnect and reconnected the battery, the issue persists.
Any help, please!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Did you install the flex cable correctly? You'd better ask professional to help you find out the problem.
さんによる
コメントを追加
1 件の回答
ベストアンサー
I had the same problems with mine ipad 2 3g
I had damaged the antenna's, after replacing them the problems where solved.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Robert G さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,198
