iPad Mini touch replacement went really really bad.
I changed an iPad mini touchscreen, not first time doing this.
Well the thing is that everything went to s#!t.
My standby wake button doesn't work.
My touchscreen stopped working. i even tested another touchscreen with the little connector board already soldered and didnt worked either. Then i tested both touchscreens and worked properly on a different iPad Mini.
The battery is at 78% and im getting the full charged icon.
It is restarting itself every 5 to 10 minutes.
I was able to perform a restore via itunes, but the issues persists.
I disconnect and reconnected the battery, the issue persists.
Any help, please!
この質問は役に立ちましたか?
1件のコメント
Did you install the flex cable correctly? You'd better ask professional to help you find out the problem.
alinachau さんによる
