メインコンテンツにスキップ
The Canon Powershot SD790 IS is a compact 10.0 megapixel digital still camera with built-in flash and a 3x Optical Zoom. It was released on March 2008.
10回答 すべてを表示
camera reads, no memory card, same read with new card
how do i get the camera to recognize memory card.
to clarify, i am able to read the memory card using the computer, i can see the photos and data, and both cards work in other devices.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
clarence, just to clarify, it does not read the cards at all? You tried the cards in another device?
さんによる
コメントを追加
2件の回答
ベストアンサー
Look inside the SD card socket in the camera (use a flashlight) and check if all the pins are OK, check for misaligned, bended or corroded pin(s). The problem could be caused by a bad contact from the SD card to the connector pins.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I followed your advice and the pins appear to be in position and normal.
さんによる
コメントを追加
What size SD card are you trying to use? I believe that model can't use a SD card larger than 2GB. If it's greater than 2GB, it uses a different memory format and cannot be read.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
i've always used a 4GB, recently bought a 16GB and it also worked fine in the camera
さんによる
As oldturkey03 asked, "clarence, just to clarify, it does not read the cards at all? You tried the cards in another device?"
さんによる
コメントを追加
回答を追加する
clarence さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 9
今までの合計 299
