メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
794回答 すべてを表示
締切られた回答
Skype prevent from sleeping with open lid (automatic sleep settings)
For some time already it not sleeping automatically
I have tried to do all possible things to fix it ,and now i have found out that it is Skype which is preventing computer from sleeping ) ANd i saw there are people having same problem but on Windows )
So i would appreciate if someone can tell me what to do with this ?
(one thing is ok - if to have old versions of Skype this is not happening ,but any after 5.5 version of Skype make this effect - preventing from sleep )
As i read what people say = problem is in a Skype updater services,i dont know how can i delete this maybe ,cause all setting i have are good )
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Will the computer sleep if you quit Skype?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
yes! it sleeps perfectly now ) when quitting Skype) Have tested it !
さんによる
コメントを追加
You have had problems with kexts involving sleep mode (1, 2) before. Have you tried removing those kexts again?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
HI ! That problem with kext is old , and it have been solved in a very simple way ,there i have posted - (i was not a kext problem) it was easiest solution i just needed to delete this file- com.apple.PowerManagement.plist and com..apple.AutoWake.plist files
I even felt silly that after doing so many operation with computer it was so obvious
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,548
