メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
締切られた回答
iPhone 4 Touch Screen is not working?
The iPhone was working properly, had never been opened and all parts were OEM. I was using it, then i set it down for a few minutes and when i turned it back on the touch went out.
I put in a different digitizer and nothing, then i a different motherboard with my digitizer and the touch worked. It's a problem with motherboard? iphone has been dropped many times but always kept in an otterbox.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
JD925, since you digitizer works in a different phone, you can rule that out. Try to restore the iPhone and see if that makes a difference. If not, check all your connectors. Make sure there are no bend, broken or corroded pins. If those are okay, you may have a bad touchscreen IC. Hope this helps, good luck
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It's possible for the touch IC to simply go bad out if no where,???
さんによる
コメントを追加
see does itunes detect it? if it doesent try this
Here's a tutorial with pics that everyone has been requesting. I've used this method over a dozen times successfully. Good Luck!!
There are 3 small battery terminals (shown below). You only want to touch the one to the far right (circled below). Avoid touching the other 2 terminals!!
see the pics
http://guide-images.ifixit.net/igi/YiaQu...
http://guide-images.ifixit.net/igi/AnevP...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 4,771
