メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル A1040 / 10、15、20、30、または40 GBのハードドライブ / タッチホイールの上部に4つのタッチセンサー式LEDバックライトボタン
Why won't the iPod turn on?
Hello All Hopeful Helpers,
My 3rd gen. iPod 10 GB with the 4 buttons above with touch wheel won't start up at all. I've tried to hit the play button then the center wheel button alternately but it just won't turn on. (The Hold switch is not on.)
Can anyone help? I miss my music!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
6件の回答
最も参考になった回答
have you tried resetting the iPod? see: http://support.apple.com/kb/HT1320
What happens when you plug it into the dock connector? does it charge or power on? anything?
does your iPod still have the original battery? if so maybe the battery is dead - the battery on my old 20G 3rd gen iPod died and had to be replaced long long ago.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Are you trying to charge it via USB? You need to use a 30-pin to firewire cable and charger, or an iPod dock. The 3rd gen iPod can’t charge with a USB cable like the other iPods can.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
That looks OLD
I bet the battery has had it - what if you have it on iTunes - any luck?
could be the HD as well - those things don't last forever
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thanks for your replies. I have tried to use with the power cord and when hooked up via computer...still nothing. I reckon the battery is dead. Does this mean I've lost my music and other data on it?
I have not tried resetting it and will check that out. Does that mean I will lose all of my music and other data?
I'm already 'used to' the idea that I've lost it all, but it would be a nice 'present' if I were able to recover this stuff.
Again, thank you.
さんによる
Changing the battery is generally safe for the data. If just the battery is dead, the iPod should boot up again once the new battery is in place and charged. You may need to plug it into a wall charger for a while to get the battery out of "storage mode" (sometimes lithium batteries ship partly charged, but switched off).
Resetting the ipod (as in turning off and on) is safe for the data. Restoring it in iTunes will delete the data.
If the hard drive is dying, you MIGHT be able to get some of the data back with a disk cloning tool or data recovery program (such as the "dd" command in Linux, use with caution).
さんによる
コメントを追加
The people at the apple store told me it's usually the motherboard when it won't do anything at all under any circumstances.
If it is the mobo that means you music could still be intact on your hd, you would need a donor ipod, or 1.8in drive adapter to get it though.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
REPLACE THE Battery find it on ebay
mikey88772
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Does this mean I have to buy another battery ? Or can I do something else
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Have you tried plugging it into your computer? if so and no response, then yes you will likely have to change the battery
さんによる
コメントを追加
回答を追加する
gbird さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 26
今までの合計 15,626
