メインコンテンツにスキップ
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99回答 すべてを表示
Does anyone have a guide for replacing the LCD panel?
My aluminium-cased Apple Cinema HD Display (23") has developed a pink hue around the perimeter.
Rather than discard the whole unit, I'd like to buy another from eBay with a good screen but scratched up case and swap out the LCDs.
Can anyone provide a link to a service manual or other take-apart guide to help with this?
Thanks very much,
Adam
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Adam Dimmick, see if this will help you out:"
1. FOOT REMOVAL
1) Remove three screws (a).
2) Remove the Foot.
2. BACK COVER ASSY & REAR SHIELD REMOVAL
1) Remove twelve screws (a)-1 & (a)-2.
2) Remove rear cover.
3) Remove the rear shield.
3. HINGE & EMI SHIELD REMOVAL
1) Remove two aluminum shielding tape (a), (part of shield tape kit 076-0978).
2) Remove four hinge screws (b).
3) Remove the hinge.
4) Remove four shield screws (c).
5) Remove the Metal Shield
4. MAIN ADC CABLE & USB CONNECTOR
REMOVAL
1) Remove four screws (a) & (a)-1.
2) Disconnect J12, J702, TMDS connector.
3) Remove main ADC cable.
4) Remove four screws (b) & (b)-1.
5) Disconnect J11 connector.
6) Remove the USB connector.
5. MAIN BOARD & INVERTER BOARD REMOVAL
1) Disconnect J703, J701, J705, J704.
2) Remove four screws (a).
3) Remove the main board.
4) Disconnect CN1, CN2, CN3, CN4, CN5.
5) Remove screw (b).
6) Remove the inverter board.
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
OldTurkey03, thank you for going to that effort but unfortunately those instructions are the for the plastic-clad (older) Cinema Displays and mine is of the newer aluminium variety (model A1082) and so these instructions don't apply.
If you happen to have a similar set of instructions for the newer variety that would be fantastic!
Thanks for the response though!
さんによる
Adam Dimmick, in the meantime, check these instructions. Should get the proper service manual soon and will post an update.
さんによる
This is the older plastic display.
さんによる
The link in my subsequent comment should be showing the newer HD display :-) Let me know if it does not.
さんによる
Hi OldTurkey - those photos are a big help. The service manual would be even better! From you experience, do you think it is possible to swap out the LCD panel and/or backlights from one screen to another?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Adam Dimmick さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 1,922
