メインコンテンツにスキップ
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312回答 すべてを表示
締切られた回答
Temp sensor connector broken, where to solder? HF/E1, see picture
Dear,
Someway or another I have managed to broke the connector of the temp sensor on my macbook air A1237.
Now I want to repair it, and solder all the cables back to the connector, but I don't know where they should be soldered as it is not clear.
I have marked the cables on the board with 1,2,3 and 4.
Can someone please tell me where to solder them, see picture:
Thank you very much in advance for your help !
Kind regards,
Benwake
EDIT:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
When you say "solder them back" what do you mean, see that the board where they are connected is not connected to the main board but until I can see from another angle I can't really help you very much.
さんによる
Hi,
Please check the image above.
I need to know where to connect the cables from the square part to the connector.
Thanks in advance
さんによる
コメントを追加
1 件の回答
this shows it
You have it in the right spot, just figure out how it was attached. I don't think it's soldered, probably glued.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
That is actually my problem, I don't know how it was attached. I should need to know which cable from the connector goes to where on the square piece :/
This is actually what I am doing now:
http://benwake.com/upload/SDC16400.JPG
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 959
