メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
締切られた回答
iPhone contact list missing and phone will loop unless you charge it
For the past month, my 3Gs has been looping between the main screen and reloading. When it does this, I will plug it in and it stops. However, it wipes my contact list clean. One of the most recent times... It would not allow me to hook up to the USB to restore the contacts. Also when I go to charge my phone in the wall, I have to shut my phone off in order for it to recognize the charge. When it recognizes it, the phone will turn on. PLEASE HELP! I need a solution for a quick fix to last me two more months before I can get a new one. Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
Cath, there is really no quick fix:-) but I suggest that you replace the battery. The signs and symptoms you describe would fit a bad battery. Follow this guide and replace the battery with one like this. Hope this helps, good luck.
iPhone 3GS Batteryの画像
製品
iPhone 3GS Battery
$14.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
There are three kinds of recovery mode: to recover data directly from the iOS device and to retrieve previous data by extracting it from iTunes and iCloud backup!
I think use the iPubsoft iPhone Backup Extractor to recover lost contacts from iPhone backup is the best way for you to get back them.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
With the growth of the use time of your iPhone, there will be more and more call records on youe iPhone. While you are cleaning up the trashy entries, you may mistakenly delete what are important to you and haven't been stored to address book, or sometimes you may clear all items of your call logs. That's bad thing but take it easy now, the Coolmuster Data Recovery for iPhone iPad iPod can help you recover the lost or deleted contacts from iPhone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
For this situation, you can recover missing contacts list from iPhone by following 2 ways.
1. Restore the deleted contacts from iCloud.
2. Extract contacts from the latest iTunes backup file.
Both Methods requires that you have done backups before. Because of your iPhone hardware problem, I suggest you should complete the recovery by third-party tool iPhone Data Recovery, which can help you selectively extract data from backup and save them on computer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 287
