メインコンテンツにスキップ
締切られた回答
How do I install tiger?
I have an iMac g3 graphite 600 MHz with a cd-rw and i recently installed OSX 10.2 on it, I got OSX tiger and tried to install it, and it ejected it, so I bought a dvd-rw (usb) and tried again, it recognized the install disk, i hit the restart button in the installer to continue, but i just booted back into 10.2, any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
problem solved! I used my iMac G4 17" in target disk mode to do this =D
さんによる
コメントを追加
2件の回答
ベストアンサー
You need to use the firewire port to do this installation or to boot from an external DVD or CD.
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
I am trying to boot from this dvd
さんによる
FIREWIRE not USB. Your machine will not boot from an external USB.
さんによる
is there a way I could rewrite tiger into a cd and boot off of it (in the main drive)?
さんによる
I would put osx tiger in the dvd-rw and put blank cds in the cd slot
さんによる
Run "get info" on it to see if it is small enough to fit on a CD. Do you have another Mac so you can use Target Mode?
さんによる
4件以上のコメントを表示
コメントを追加
最も参考になった回答
Minimum install requirements for Tiger:
  • At least 256 MB of RAM
  • At least 3 GB of free disk space; 4 GB if you install the XCode 2 Developer Tools
It would help to know any dialog or error messages that went along with the install fail.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
hard disk is 30gb
and the ram is flat out 256 mb
さんによる
the product I got was the samsung ultra thin portable dvd-rw drive
さんによる
As per mayer, you'll need to put the iMac in target disk mode, connect VIA FIREWIRE from one of your other machines, boot and select your iMac then install.
さんによる
Target Mode connection will need to be via FireWire and to a second Mac. This Mac is acting as the master to your iMac (slave) so the iMac's HD is seen as an external disk to your master system. - Another way here is getting an external FW HD (don't need anything that large) to first format and install your new Tiger OS on to it then copy the installation files from the DVD to the HD then use the Startup control to select the external disk as the boot volume to then boot and install the new OS from. A side benefit of doing this is you then have a backup drive to repair your system as well as hold anything you don't want to loose (just in case).
さんによる
ok, which mac should I use? the intel or G4, and yes i have a firewire cable that I can use
さんによる
1以上のコメントを表示
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 1,791
