メインコンテンツにスキップ
Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
530回答 すべてを表示
Can I fix the Logic Board?
My iBook G4 will not boot up. It doesnt chime. I took it to the Genius Bar and they said that it was the Logic Board so is it posible that it could be repaired from the info I get from this site. Please Help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Please be more specific about the problem. Do you get any activity when pushing the power switch button ? Do you hear the hard drive spinning or the optical drive reset when trying to power on ? Any light on the keyboard (caplock) ? Any light on the AC adapter tip ?
さんによる
コメントを追加
2件の回答
ベストアンサー
First unplug the AC charger and remove the battery then hold the start button down for 5 seconds. Plug it back in and try. Next hold down the command & option and P and R keys and hit the start button, wait till it tones three times.
Try starting it up from the installation DVD. Insert the disk, hit the start button and finish pushing the disk in. Immediately hold down the "C" key. If this fails tell us what happened incuding any sounds or lights and we'll go from there.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
hi, my problem is that after 20-40 mins i get a message stating that you need to restart but it freeze up so the only thing you perform is shut down using the power button. took it to tekserve they said $350.00 plus tax , they are not going to fix it but send to apple. can it be ifixit?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Please start your own question so we can give it individual attention. Thanks
Just copy and paste this into a new question.
さんによる
コメントを追加
回答を追加する
Andrew さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 991
