メインコンテンツにスキップ
モデルA1369、1.6、1.7または1.8 GHzプロセッサー、64、128、または256GBフラッシュドライブ
328回答 すべてを表示
締切られた回答
Failure to start up.
Hi,
My Mac air just died on me. It won't start, at first I thought the battery died so I charged it up and I pressed on the start button, no response there.
I hadn't dropped it or there was no contact with water or whatever I could think could be the reason for its failure.
Took it to an apple repair shop & 4 days later they told me the motherboard s kaput. And it's going to cost me 540$ here in Thailand.
What should I do?
Kiara
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
That sounds like a fair price for an essentially new MacBookAir. Due to your location moisture probably corroded the logic board (a common problem in the tropics). You may want to invest in Applecare - check first that it would have covered the damage... your environment may preclude coverage/damage.
In future to prevent the reoccurrence whenever possible keep the machine in an air conditioned, humidity controlled environment. When that is not possible store the machine in a closed (sealed) container with a desiccant; uncooked rice is a commonly available desiccant. If not in use for long periods of time change the desiccant every few days.
Good Luck,
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 442
