メインコンテンツにスキップ
締切られた回答
wifi issues after replacement of wifi cable
I re placed the wifi cable on my ipad 2 but the wifi still does not connect. Is there some other fix for this problem other than a simple reset in settings or a restore through itunes?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Depending on which iPad you have, if you will look at the opposite end of the board that the wifi antenna is plugged into. On the opposite end of the board, on the under side of the board there is another antenna plug that I found had came unplugged on my ipad2 gsm.
You can see a photo of it on the ipad 2 teardown s where i believe i saw that at.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Would replacing the speaker assembly help this problem as the wifi antenna screws into it? I'm not sure if the connection would be interruped because of a malfunctioning speaker (although, the speaker seems to be working fine!).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 227
