laptop says plugged in but not charging.
This problem started 3 months ago, all I had to do was unplug it and then plug it back in and it would charge fine. Now nothing works it just says "pluged in (not charging)" now.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
This could be an indication that the battery wont hold a charge. Might need to replace the battery
このアンサーは役に立ちましたか?
It seems like you battery is expired because usually laptop`s battery last for 1 to 2 in normal form. So if your laptop is a year or two older then you would defiantly need to replace the batter and make sure to order the proper OEM replacement battery because other aftermarket ones wont give you very good output.
このアンサーは役に立ちましたか?
I was change a battery last week but still plugged in not charging
過去 24時間: 0
過去 7 日: 6
過去 30 日: 6
今までの合計 1,590
1件のコメント
Use this : Dell AC Adapter LA90PM130
Steve Redtone さんによる
