メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ASUS製ノートパソコンの修理ガイドおよび分解情報。
Why isn't my mouse working?
My mouse won't show up on my screen and I can't click on anything. The laptop is brand new and I'm already having trouble.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 146
40 件のコメント
I have labtop and I've tried every trick that you guys are giving...I get nothing, any more ideas?
さんによる
mine says device not migrated om on windows 10 help
さんによる
My mouse has a red light when i turn it on {Witch means its working}.
But the mouse icon itself will not move around i am working on a project
please reply
さんによる
i have a desktop got 10 day before yesterday, lazer light is on but screen mouse arrow doesn't move, any ideas?
さんによる
roll back worked a treat
さんによる
35件以上のコメントを表示
コメントを追加
18件の回答
ベストアンサー
Check for a function key that turns the built-in mousepad on and off. Mine is a silver button on the top left of the keyboard. It drove me crazy until I discovered it.
このアンサーは役に立ちましたか?
スコア 88
109 件のコメント:
On my laptop apparently it's Fn + F9. Thank you! It was driving me crazy too.
さんによる
I want to thank you because me too was driving me crazy.....I have been trying for hrs to figure it THANK YOU again....
さんによる
GOD Bless you - Fn F9 fixed it immediately. Thank you
さんによる
Thank you. I had the same problem and I used Fn F9 and the issue solved.
さんによる
thank you! Fn F9 fixed it
さんによる
104件以上のコメントを表示
コメントを追加
You have to restart the computer and after restart the computer, It would be work
and after restarting if mouse doesn't work so..
You have to update the drivers . for additional steps visit '''FIX-mouse-not-working-in-computer'''
Follow these Steps:
a) Press the Windows + R key on the keyboard.
b) Type devmgmt.msc in search box and click on OK
c) Right Click on Mice and other pointing device
d) Click on update drives then click on Search automatically
Then restart the computer.
After that Mouse doesn't working So:
Then try to change USB port of Mouse. Please let me know for any other issue .
このアンサーは役に立ちましたか?
スコア 21
7 件のコメント:
How are people supposed to click on those things if their mouse isn't working?
さんによる
that is exactly what I'm saying
さんによる
I was Thinking How You Even Got Here ... Use Your Phone..Thank You Peter
さんによる
Thank-you! A reboot fixed the problem.
さんによる
thanks bro
さんによる
2件以上のコメントを表示
コメントを追加
If the mouse is a corded USB, try it on a different computer, if it works, then plug the mouse into a different port on your laptop. If it is a wireless mouse, check the batteries, and try moving the USB receiver to another port and installing the drivers.
If that doesn't work, when the system powers on go into the BIOS setup and make sure that all of your USB ports are turned on.
If it is the trackpad, and you are having other issues on a brand new laptop, you may need to contact the company where you ordered it from and let them step you through any specific troubleshooting problems and/or request a RMA or refund (worse case scenario).
このアンサーは役に立ちましたか?
スコア 9
8 件のコメント:
I will keep that in mind and be more specific with other questions. Thank you.
さんによる
oh my GOD ! iam a woman and i am very lack with those things!! and you just solved my problem in a minute . oh my god . thanks and my God bless you.
さんによる
what the !&&* does being a woman have to do with installing a mose?
さんによる
I tried all above options. Fn+F9 ....touch pad disables but still mouse does not work. I tried different ports, doesn't work. I assumed ports are damaged (my kitten often walks on laptop as red carpet) but external fan and printer are working excellent on same port. What do I do? How to reinstall mouse? Please advise me. It is time consuming with touch pad, mouse is faster
さんによる
mine is a laptop and i can't see or move the mouse
さんによる
3件以上のコメントを表示
コメントを追加
On new touchscreen Asus laptops the trick for turning on the mouse is to press fn+f9. I had to go three weeks like this until I could figure out what to do. Also if your screen gets turned sideways or upside down. {my brother did that to mine} press ctrl+alt+up arrow. If you press the wrong arrow do it again until it goes back to normal.
このアンサーは役に立ちましたか?
スコア 4
11 件のコメント:
dont work on mine
さんによる
man i love u
さんによる
Mine doesn't work it's a toshiba ?!? Any help
さんによる
i have a toshiba its a brand new laptop only had it for a couple months then the other day the mouse just disappeared. i tried the fn f9 but its not working
さんによる
I have toshiba its a new laptop I tried the fn f9 but its not working..any help please!?
さんによる
6件以上のコメントを表示
コメントを追加
It seems that there are many Fn + F- keys if you see on your Pc look for a F- button with what looks like a No symbol, you know the one with a circle with a line through it and a hand to the right pointing at it. For me i Pressed Fn+F7 and that worked if this helps anyone yw. Good Luck
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
I bought a new asus r558u with dos.I had to install Windows 10 using Keyboard only..I thought it was drivers problem....then fn+f9 made the pointer to come back...thank you very much
さんによる
@xpzharlock thanks a lot sir the way you described the function key's special function symbol helped me a lot thanks a lot from bottom of my heart as i was like how to fix this issue what has gone wrong etc. as i followed few suggestions like fn+f9 but that didn't solved the case
i am really thankful to you that you explained in such a fantastic way thanks a lot sir
with regards
MOHAMMED MUZAMMIL
さんによる
my fn key that looks like a no is f9 and it still doesn't work.
さんによる
F7 worked! Lifesaver
さんによる
コメントを追加
try pressing [fn] + f1 or wherever the icon of a computer screen with an x is on. Hope it helps!
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Yay. I was going nuts. Thanks. On mine it was Fn F10. The description of the icon was very helpful.
さんによる
THANK YOU!!!! This has been driving me crazy for weeks!
さんによる
Thank you!!!!!!!!!!!!!!!!!!!!!!!!!! It was stuck and not showing on screen. It was driving me crazy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! THANKS!!!!!!!!!
さんによる
YOU'RE A LIFE SAVER I DIDN'T KNOW WHAT WAS GOING ON- also the button isn't a computer screen it's a touchpad lol, makes sense since it turns the touchpad on and off.
さんによる
Thank you ...?
I am sorted good people.
さんによる
コメントを追加
click the button that gets you into the asus vivo book mode. it's a little diamond iconed button on the top right corner of the keyboard for me.
then you have this little profile of your comp come up, like memory used, etc, and one has the touch pad either on or off. somehow mine was disabled and put into off. I switched it on on and my mouse icon came back!!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
My ASUS mouse has a small on/off switch on the bottom. More like on/gotcha switch!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I tried every suggestion on here and a couple other sites. Fn + f9 or fn + anything else didn't work. I did try fn + f3 and it worked! apparently it's the f key with the symbol that looks like a mouse and a line across it from one corner to the other (the x one didn't work on mine either). Hope this works for those who are still trying to figure this out.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Tried everything. Still not working.
さんによる
コメントを追加
I have a problem..usb mouse not working. I try search net to settle it. I find out...can on back USB device with enable device icon click..to get it working back.
Go device manager there click into universal serial bus controllers then click choice composite devices properties that have enable icon button , just click on it..to open the USB device function back. After follow the step ,click next then USB mouse function back like normal.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I just purchased a new ASUS laptop. I updated to Windows 10 immediately so I could get used to everything all at once. I use a small external mouse for travelling, and the touchpad quit working the second I plugged it in. Even after I disconnected it from the USB and restarted, the touchpad still would not work. I was told this is a bug and they are working on it.
After I read through the comments here, I went to Settings, Devices, Mouse and Touchpads, Additional Mouse Options and there it was under ELAN it said it was disabled. I enabled it, and now I can use the touchpad!
Thanks!!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I don't see any E-LAN.
さんによる
コメントを追加
Honestly, I just turned my computer off and on again. You may need to restart it, though. My mouse was freezing and when it was moving, it would just be zooming the screen in or out. So far it's working, I'm not sure if this fix is permanent. Ironically, it was the last thing I tried, but it should've been the first thing I tried.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I Think You Should Checkout This See If This Helps -
Unplug Your Mouse and Wait For 1 minutes And Plug It Back
Restart Your Computer In Safe Mode With Networking
Follow Steps To Get safe Mode Visit How To Boot Windows Computer In Safe Mode Now In Safe Mode Please Go to device Manager And Update the Mouse And Pointer Driver .
Restart The Computer and Get Your Mouse Working .
Hopefully this May Work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My fix was fn+F1. I'd suggest looking in your function keys and pressing fn+the function key that has the diagram of the toupad on it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My Acer laptop has the touchpad sign of a pointing finger at F7.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine's an ASUS and it was fn+f6.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If your mouse isn’t showing up, try restarting your laptop first. Check if the mouse is properly connected (USB port or Bluetooth paired). For touchpads, ensure they’re not disabled by a function key. Since the laptop is new, updating drivers or contacting support may quickly resolve it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Had this happen on a new laptop before and it ended up being the touchpad getting disabled somehow lol. I’d try restarting first, then hit the touchpad function key (usually Fn + one of the F keys) or plug in a USB mouse and see if that works.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bailey さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 44
過去 30 日: 254
今までの合計 549,718
