Replace Superdrive with 2 hard drives?
Is it possible to replace the superdrive with two 2.5" hard drives? Just want to use duo SSDs to replace cost.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Ronnie - You only have two SATA ports in this system both are in use (current HD & Optical drive).
So you'll have to decide which device you are going to swap out. You can either take the optical drive out to install a second HD or SSD or take the current HD out and put in a SSD.
There isn't enough room or power or I/O connections to supply a third device.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,571
