Faded green color on printouts
both text and photos
Color laser printer capable of printing up to 8 colored pages per minute.
評価: 1
Apparently seems like your drum`s specific ink level is low. You can try by taking out your drum and putting it back after carefully cleaning it. If not then you may need to check with your printer support or you may have to change your drum.
Most likely its a faulty toner... The focus would be on the Yellow or Cyan toner. Access the control panel on this printer by going to print menu to print "color self test page" when printed this should show you the faulty toner by its off color appearance on the printout.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 793
