メインコンテンツにスキップ
Nintendo DS Liteは、ニンテンドーDSの後継モデルとして2006年に発売されました。このデバイスの開口作業は簡単で、修理もシンプルです。
316回答 すべてを表示
Touch screen not operating correctly
My sons' DS lite (a year old) was dropped and although no obvious damage, the touch screen is not working properly. Although the touch screen responds to most taps with the stylus, it appears that the positioning is not right and 'off position'.
I have tried caibrating, and although I can tap the stylus on the small red boxes during this process, the calibrating procedure does not 'finish' and check positioning via red squares that turn blue in the final check. Instead, the program keeps looping around the calibration sequence, asking for stylus input for LH top red square, bottom RH and and middle - taking all of this in and going round again and again in this sequence. Is this a programe/software fault or something broken within the screen??? What should I do??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Helen Lowe, it seems to loop because it can not read any input. Sounds like a fractured digitizer circuit. Here is the guide to repair it. The digitizer is available at places like this. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Hi Helen.
I actually had this same-ish problem with my DS a few months back. If you have had it for less than a year, you can return it along with your proof of purchase to either the store you bought it from, or you can deal directly with Nintendo.
If not this sounds like a problem with the touch screen itself. What you can do if you are adventurous enough is take the DS apart and check if the touch cable is loose. If that doesn't fix it, you could order a new one. They are very cheap, around 5 bucks for a new touch screen.
I hope this helps!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Helen Lowe さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 22
過去 30 日: 83
今までの合計 11,019
