メインコンテンツにスキップ
モデル番号A1288/ 8, 16もしくは32 GB容量
451回答 すべてを表示
Will unit work without screen attached?
I got an iPod that was smashed up pretty bad, but seemed in not bad shape. The ribbon cable attached to the lcd has come completely off the screen. Can this be re atttached? Also, will the unit no longer sync with a computer because the screen isnt attached?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
最も参考になった回答
I plugged in a parts iPod I got that is a 2nd Gen to my laptop and Itunes recognized it and saw that it was a 8 gig model with nothing stored on it. This parts iPod did not have a Touch Screen or LCD installed. This does not prove that it will work correctly if I install a new touch screen and LCD but it did prove it was not totally a dead 2nd Gen iPod
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It should, the only problem, is that it you want to do anything with it, other then have a $300 flash drive, you will need to install a screen, since the only interfaces it has other then the screen are the lock, home, and the volume switch. You should be ablt to sync it, but you may run into the issue of a passcode lock. If there is a password, you will need to unlock it, and with no screen, that may be quite challanging. You could put it into DFU mode, restore it, then you can sync it with no problem.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My ipod felt the screen smash and it didn't work.What should I do to fix it.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
start your own question for that - it would be the first step
さんによる
コメントを追加
回答を追加する
ian さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 6,544
