メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
water damage :( HELP
So i dropped my iphone in the pacific ocean.. normal right? anyways, i replaced the dock connector & battery but it's still giving me problems. It only works when connected to an AC outlet & works for 5 minutes before it reboots. In those 5 minutes I have no wifi, or att signal, no sound, no vibration. Everything works great besides that. paying 200 for the replacement is out of my budget. I can't seem to restore the phone either because several errors occur. I've already tried the rice method and now im just desperate and depressed for answers/suggestions.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
californiaxfresh, besides the "rice method" does not work. Rice does not do anything! I would most certainly suggest that you clean your logic board a bit further. Use this guide to clean your phone. It was written for a 3G but all the points still apply to your phone. The issue here is corrosion caused by the Pacific water. Rice will not clean the board at all. After you clean your phone, reassemble it and re-evaluate.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
thanks for replying old turkey! yeah i just took apart my whole phone and cleaned out the logic board. i found some sand in there. unfortunately while i was cleaning the board i also cleaned the white sticker so now its a little pink :(
さんによる
Is a moisture indicator that would show Apple that this phone was exposed. This will not impede the function of the phone.
さんによる
Yeah i understand. do u think i should keep going to the apple store in prayer that they might give me a free replacement?
さんによる
You could try, worst case scenario will be a "No" :-)
さんによる
if i tried cleaning my logic board and its still not working (i cleaned it with 70% rubbing alcohol ;) is it time to give up?
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
californiaxfresh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 1,043
