メインコンテンツにスキップ
iPhone 4のCDMA版モデルです。修理はそのままパーツに作業をしますが、フロントガラスとLCDはユニットで交換しなければなりません。16もしくは32 GB / Model A1349。
295回答 すべてを表示
iPhone 4 wont charge after replacing charge port
So as the title says I have this white Iphone 4 that refuses to take a charge. Originally it wouldn't take a charge, but would detect power, and connect to a pc. So after some searching it I found it to be a bad charge port. When the part comes in I install it only to find it still wont take a charge but does detect the power and can be seen by a computer.
I have already tried the battery in a different iphone and it was able to charge that way. I'm thinking it's something on the logic board that is bad.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
It sounds to us like a faulty motherboard component on your iPhone 4S. Your logic and sequence of repairing the iPhone is spot-on. If the charging port or the battery are not the issue, then it leads me to believe that the motherboard has a faulty component.
In our repair shop, we use the same repair flowchart (sequence) when we get a unit in with similar problems.
Rick
Florida iDoctor
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
My Samsung GT-S3850 won't open when turned on. It keeps on showing its model info and the intro display; later it advises that the time and date needs to be reset after changing the battery. And the same notice keeps going on and on.
What could be the possible problem and how can it be solved.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
eddie さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 3,610
