MacBook Pro 13 inch battery change?
is it possible to replace the battery?
この質問は役に立ちましたか?
If your just wondering whats involved checkout the iFixIt teardown. MacBook Pro 13" Retina teardown
If you think your battery is having troubles you should bring the system to a Apple Store as its likely covered under warranty (less than a year)
このアンサーは役に立ちましたか?
It is possible however apple has made it so that you have to replace the top case in order to replace the battery as it is part of the top case. This is not going to be a customer installable-part. Your computer should still be under the first year of warranty, aka apple limited warranty, and if your battery is defective, they should replace it. Hope this helps!
このアンサーは役に立ちましたか?
tell me please iam change the top case mac book pro retina display i will also change the battery
このアンサーは役に立ちましたか?
Please review the IFIXIT guide
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 3,806
