iPhone 4S screen on an iPhone 4 ( cdma )...
Hello,
Can I use an iphone 4s screen on an iphone 4?
What is the bezel?
このアンサーは役に立ちましたか?
The front screen bezel is the thin plastic frame with the 10 screw tabs at the edge of the glass.
The 4 & 4s can universally fit each other. replacing the bezel is the best way, but if you don't have the time or the proper adhesive to re-seat the bezel to the glass, you can simply, cut off one screw tab on the bezel & and cut the end off of another & a CDMA screen will seat on a 4s frame.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,349
