メインコンテンツにスキップ
締切られた回答
Need help locating and jumping power connector (no top case/button)
I've got a 17" Aluminum Core 2 Duo MacBook Pro, well most of one anyway. The case is broken up pretty badly and the top case, keyboard, trackpad, and power button are missing. I've been told it still boots (MB and LCD are intact and everything is still attached) but I can't figure out how to jump the power switch connection on the MB, or even where it is. Can anybody help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
I have a PB 15" alu with the top case removed and i can see two contact points on the logic board with an inscription POWER BUTTON written aside of the contact points. On the PB the contact points are located near the top case cable connector. Look carefully on the logic board to find the contact points or maybe someone here can indicate where exactly they are located.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
I was looking for an answer for this OP myself and all I find is the connection for the top case. I would have no ides which two pins were the power switch--perhaps you can tell. Ralph
http://s1.guide-images.ifixit.com/igi/CK...
さんによる
Awesome! It is the third pair of pins (from the left). I jumped them with a fork and all is well. Thanks!
さんによる
Glad it worked. Ralph
さんによる
コメントを追加
Would this work on a mid2009 Macbook Pro A1278? If so, where might i find the two pins on that motherboard, it looks completely different!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Here is a MacBook Pro 15 inch Early 2008
http://img.skitch.com/20120104-bb8d3xaut...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Derek -
It's at the end of the ribbon cable that connects the keyboard/trackpad skin. The two leads for the power button will be somewhere along that ribbon - jump each pair with a paper clip until you get the right one. And you needn't worry about shorting anything out if you hit the 'wrong' pins. At least not along that connector...
- Joe
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 9,230
