turning on but shutdown after few seconds minutes.
hi guys. my macbook A1342 shutdown. then after shutdown the power indicator(green and orange light) immediately turn green even its not fully charged. i removed the charger then plug it in. then pressed the power and it turns on for like 30 seconds and then shutdown. i pressed the power and not responding. i unpluged and plug and then turn on same thing happen. i tried to SMC reset but and it only gives me 2mins then shudown again.i tried PRAM reset for 2x it went ok but for only 2 hourn and shutdown again. now, i'm back to 2mins maximum before shutdown. hope you understand this msg. thanks guys for help
この質問は役に立ちましたか?
2 件のコメント
Has this been exposed to liquid? Are you operating this on a flat surface, such as a desk, or an uneven surface (your lap)? Is the fan running? If so fast, slow? Download and install iStat, tell us what it has to say about your temperatures, fan speed processes. It is a free widget/program. Click here to read about it and download it. Please tell us more about your system: What version of OSX, how much RAM, recently updated/upgraded firmware or hardware, etc... ?
ABCellars さんによる
hey Dan thanks so much for fast answer! i found out that the problem came from chargers magsafe. i borrowed my friend's charger and works fine. so i check my charger and saw the lose connections. i forgot to mention that i did openned it before(chargers magsafe). thanks for the answer!
insame さんによる
