メインコンテンツにスキップ
Disappointing performance gain from increased RAM
I recently upgraded the extra RAM DIMM in my 800 MHz iBook G4 from 512mb to 1gb. I'd been hoping for a big performance bump, but I haven't really noticed much of a difference. I'm just curious if anyone has had a similar situation and if there might be something I'm failing to do to take full advantage of the additional memory.
The memory does show up in the System Profiler (128mb built-in plus the 1 GB DIMM).
I'm currently getting a 22.04 Xbench score. I tested before I upgraded the memory, but unfortunately didn't save those results. But I'm vaguely remembering a score of 19 or 20 with the 512mb DIMM.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
in the real world?
is the computer faster doing stuff you want?
less beachballing?
I mean. it s still the same computer, but the extra memory will mean less swapping ....
さんによる
When I'd done memory upgrades on other computers in the past, everything immediately felt snappier. This time, not so much. The computer feels as draggy as ever, particularly on the internet.
さんによる
コメントを追加
4件の回答
ベストアンサー
The best performance gain to be had in an iBook is to replace the harddrive - Apple Shipped iBooks with 4200 RPM Drives! slap a 7200 RPM drive in, night and day.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
There's an idea! But I'm looking at the ifixit guide, and this looks like a pretty formidable undertaking. Before I start, I'm wondering if I can get a sense of how much faster the machine would run by starting up from a 7200 rpm external firewire harddrive. Do you think that would approximate the speed of the computer with a 7200 internal hard drive?
さんによる
You might get a bump, but you've already spent money, a HD will cost more plus labor, and the increase is just not going to be too dramatic. Whereas if you sell the computer for $200 on eBay and buy a 1.83GHZ MacBook for $450 on Craigslist, the $ won't be much more, yet you'll have a way more powerful machine that will last years. If you're looking at this as a fun project, that's awesome and I say go for it, but if the goal is to get done with this and use your computer, go with a MacBook.
さんによる
コメントを追加
最も参考になった回答
You didn't mention what OS you have on this machine, but I wanted to mention that there is a huge difference between the performance of Tiger 10.4 vs Leopard 10.5 on a machine of this speed. Tiger does not require the same resources as Leopard, so if you have Leopard installed, you may want to downgrade to Tiger, and you may get at least part of the speed increase you're looking for.
Besides that, unfortunately this is an old and relatively slow laptop that isn't getting any faster, so you may want to consider upgrading to a used MacBook in the $500 range, which will be a night and day difference in terms of performance.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I'm actually using 10.3.9. Do you think Tiger would be faster?
さんによる
I haven't used 10.3 in ages so I'm not qualified to say, but I would guess 10.3 would use even less resources than Tiger and probably be even faster. I think what it comes down to is if you need significance performance increase, a new computer is in order. Memory helps, but is only one factor, i.e. putting new sport tires on a Honda Civic does not make it a Ferarri. :-)
さんによる
コメントを追加
For what it's worth, I upgraded RAM in a PowerBook G4 12" 1.5ghz (I think it was 1.5ghz) to 1.25GB when I upgraded to Leopard. I didn't notice much of a performance difference either, anecdotally. I agree with rdklincorporated's advice
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks -- at least it's nice to know I'm not the only one!
さんによる
コメントを追加
1GB still isn't that much, I myself only have 1 gig on my MB, and that can barely do anything. Added to the rather slow processor you have, I wouldn't expect much.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mister790 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 2,642
