メインコンテンツにスキップ
Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
530回答 すべてを表示
My iBook is really messed up, Please help.
I am trying to fix my iBook. i don't know the exact issue though. the situation is:-
when i try to turn on the iBook it acts like it is being turned on, with all the noises and stuff (you can actually feel the vibrations or things going on inside just like a normal laptop), but there is nothing on the screen, its dark not completely like turned off dark, but dark like the screen is lighter with dark blue. . . but its like there is light that indicates its turned on, get me. the brightness is like that lowest amount but with nothing on the screen. then the noises continue, after some minutes it stops. (maybe i could upload a video?)
afterwards i put it to sleep then i wake it up. i press enter or command or shift, the laptop suddenly starts getting loud all of a sudden with its fan getting intense, (makes me think its gonna blow or something). i don't know whats wrong.
sorry for the description.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
Hook it up to an external moitnitor to test if the video GPU has gone bad. I would also hook it up in target mode, the "T" key on startup, via firewire cable to another mac to back up my data and run Disk Utitities on it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
If:
- you get normal video on an external monitor and
- the iBook shut down when you press the power button then hit the return key
you have a screen issue.
If you get black screen at boot up with fan running high speed then the logic board is faulty.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
concise +
さんによる
コメントを追加
If you see no video after trying Mayer's idea, try it again, while putting pressure on the upper trackpad, and see if it works then.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tenzin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 957
