メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
iPhone 4s battery not charging and showing fully charged sign
my iphone 4s is not charging now.. it was charging properly but now the fully charged battery sign is appearing when i connect it to a usb charger to my macbook.. its percentage is 20% and still full battery charged sign is appearing and the iphone is not charging.. i have restored it 3 times but problem has not been solved please help!
ITS NOT CHARGING AND FULLY CHARGED BATTERY SIGN IS APPEARING at 20-30% percent battery!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
5件の回答
最も参考になった回答
Hi. It seems you may have a faulty battery. You might want to purchase a Replacement iPhone 4S battery. You can follow our free step-by-step iPhone 4S Battery Replacement guide. Good luck.
iPhone 4S Batteryの画像
製品
iPhone 4S Battery
$16.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Same problem here, changing battery didn't help. Any suggestions?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
This question is almost one year old. you might get more of an answer if you ask your own question and give more details.
さんによる
Replace the charging dock, should work, I've had a similar problem
さんによる
コメントを追加
I purchased my iphone 4s via ebay and it charged fully. Then I installed the new apple update and the battery does not charge fully. It takes 12 hours or more just to reach 74% charged. What gives, do I need a new battery or what?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my iphone 4s not charging but showing full charge why that problem this is bettery problem or softwre problem please help me what to do?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
on the iphone 4S, when changing the battery and dock don't help, more often than not the issue is damage to the components next to the battery connector. You can often confirm this as you will see temp sensor and gas gauge errors in the system log with a program like ibackupbot.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
aasdeepcheema さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 9,422
