Why won't it start?
My fa50 won't start. It gets good spark,gas,air,and air compression. Why won't it start?
the main jet needs to be cleaned in the carb .. take off the carb and clean it out
このアンサーは役に立ちましたか?
Sounds as if you are not getting fuel from the carburator into the cylinder correctly, if it were me, I would remove and then clean that carburator by use of some instructions from a repair manual.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 36
今までの合計 3,338
4 件のコメント
What have you tried so far? Tried to squirt a bit of gas into the spark plug hole and try to start it, just to make sure it does get fuel?
oldturkey03 さんによる 共有
yes but dies once gas burnt
jwhiteboy68 さんによる 共有
jwhiteboy68, is this the same moped? Are you rodneylambert45? Just making sure we are dealing with the same issue here.
Here to, won't start normal ,does wel with startpilot at airfilter. When warm motor ,starts fine with kick only.
Noel De Wulf さんによる 共有
