メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
794回答 すべてを表示
MacBook does not turn on
hello everyone
my macbook use to turn on with power connected ir wouldn't charge no all of the sudden it doesn't turn on it all. when i plug the power cable i get really dim green light hard to see. also opened it up cleaned it took battery out put it back nothing is happening please help.
thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I would assume a damaged DC-in board... it started with the failure to charge the battery, and progressed (as often electrical problems do) to no providing adequate power. Switching to a new charger MAY be a temporary fix, if the board damaged the charger... however continued use of a good charger will eventually cause it to fail. Since the price of a replacement magsafe board is about 2x that of a new charger replacing the board is the smart, and economical thing to do.
If this answer was helpful please remember to return and mark it Accepted.
MacBook Pro Unibody 13" and 15" MagSafe DC-In Boardの画像
製品
$9.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jimit さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 2,523
