メインコンテンツにスキップ
OnePlus 6 Battery Replacement
必要な工具と部品
  1. OnePlus 6 Battery Replacement, Back Panel: 手順 1、 1の画像 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
  2. OnePlus 6 Battery Replacement: 手順 2、 2の画像 1 OnePlus 6 Battery Replacement: 手順 2、 2の画像 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
  3. OnePlus 6 Battery Replacement: 手順 3、 2の画像 1 OnePlus 6 Battery Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
  4. OnePlus 6 Battery Replacement, Battery: 手順 4、 2の画像 1 OnePlus 6 Battery Replacement, Battery: 手順 4、 2の画像 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
終わりに
For optimal performance, after completing this guide, calibrate your newly installed battery.
10 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
John Steven Trammell
メンバー登録日: 09/28/21
789 ポイント
4のガイドは作成済み
チーム
Clemson, Team 4-3, Hunter Fall 2021 Clemson, Team 4-3, Hunter Fall 2021人のメンバー
CLEM-HUNTER-F21S4G3
5 メンバー
14のガイドは作成済み
6 件のコメント
How do I glue the phone back together when I am done? Do I need to add more glue? Do I just heat it with the heat gun again and squeeze it together?
Timothy Magee - 返信
I agree, this is unclear.
The "Parts" section at the top includes "Precut adhesive card", but when you click on that item, it gives a whole bunch of different size options for rolls of tape (8mm, 5mm, 1mm, etc.) and it's unclear which size to get. Does anyone have details of this?
Greg -
Great tutorial, battery is fixed thank you ! If you prefer videos, this one is a good complement https://www.youtube.com/watch?v=OBN7Tc7J...
Kergara B - 返信
Battery good so far, instructions clear enough! I turned the phone on immediately after replacing the battery to make sure everything worked. This was to avoid putting the phone back together only to find it wouldn't turn on, and then having to dismantle it again.
One thing you may want to pay attention to is not to separate the screen (front) layer from the phone, rather than the back side, which is what I did on my first try.
I opted not to get adhesive strips and I simply applied thinly cut electrical tape around the phone's edges, on the outside, to keep it together after fixing. Not terribly aesthetic but does the job well enough, especially if you use a book-style phone case like me.
Pretty doable fix for a first-timer, especially when using the fixit tools (picks, spudgers etc). Happy with the results. Thank you for the guide!
Nic F - 返信
Additional tips (1/2):
1. When buying tools, consider buying a suction handle. This was useful to use on the heated back cover to open up a gap to insert the opening picks into.
2. Consider removing the SIM tray before heating the back cover.
3. When heating the glass back cover, consider wearing some resistant gloves when heating the glass back cover. The glass can get a little got and I was only using a hair dryer on the highest setting, rather than a heat gun.
4. When you have managed to wedge your first opening pick underneath the back cover, take another pick and drag it along the nearest part of the gap to open up the gap further before setting that pick into position. Repeat as you go around the entire edge of the phone. However, BE CAREFUL to not push the opening pick too deep, especially around where the volume buttons are, as the fingerprint sensor cable is located close the edge of the phone.
Adrian Wan - 返信
コメントを追加
統計データ:
過去 24時間: 15
過去 7 日: 105
過去 30 日: 540
今までの合計 21,108
