メインコンテンツにスキップ
Google Pixel 3 XL Back Cover Adhesive Installation
必要な工具と部品
  1. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: 手順 1、 3の画像 1 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: 手順 1、 3の画像 2 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: 手順 1、 3の画像 3
    • Pick and scrape away the old adhesive from the frame.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
  2. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 手順 2、 3の画像 1 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 手順 2、 3の画像 2 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 手順 2、 3の画像 3
    • Repeat the previous step for the back cover adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
    • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
  3. Google Pixel 3 XL Back Cover Adhesive Installation, Prepare the replacement adhesive: 手順 3、 1の画像 1
    • Peel away the plastic lining to expose the frame side of the replacement adhesive.
  4. Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: 手順 4、 3の画像 1 Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: 手順 4、 3の画像 2 Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: 手順 4、 3の画像 3
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the holes in the frame to properly align the adhesive.
  5. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: 手順 5、 3の画像 1 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: 手順 5、 3の画像 2 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: 手順 5、 3の画像 3
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
  6. Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: 手順 6、 3の画像 1 Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: 手順 6、 3の画像 2 Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: 手順 6、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use tweezers to guide the fingerprint sensor cable into its socket.
    • Press down on the latch to secure it.
  7. Google Pixel 3 XL Back Cover Adhesive Installation, Peel away the remaining plastic lining: 手順 7、 2の画像 1 Google Pixel 3 XL Back Cover Adhesive Installation, Peel away the remaining plastic lining: 手順 7、 2の画像 2
    • Peel away the plastic lining to expose the back cover side of the adhesive.
  8. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the back cover to the frame: 手順 8、 2の画像 1 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the back cover to the frame: 手順 8、 2の画像 2
    • Lower the back cover onto the frame.
    • Press down on all edges of the back cover to secure it to the frame.
    • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 XL Answers community for help.
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Chayton Ritter
メンバー登録日: 08/21/20
18,618 ポイント
102のガイドは作成済み
チーム
Guide Team Guide Team人のメンバー
Staff
6 メンバー
7,848のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 55
今までの合計 1,422
