Is There an alternative to the iOpener
I Dont have an i opener and i was wondering if i could use anything else that does the same exact thing as the iOpener. Thanks
この質問は役に立ちましたか?
この質問は役に立ちましたか?
A heating pad or a heat gun. :)
このアンサーは役に立ちましたか?
Very, very, very careful use of a heat gun at that!
Yea, always use it on low.
I know this is a bit late ;>)...
If you are a shop and will be doing iPad repairs on a regular basis, then a heated mat station like this is the preferred solution.
However, if this is for a one-off, the these "Magic Bags" work really well. This one is large enough to cover an entire iPad making it perfect for a digitizer replacement and you can use it at home when you have sore muscles.
このアンサーは役に立ちましたか?
I used the back of a stoneware plate taken out of the dishwasher after the drying cycle was done. It was quite warm and stayed that way for a long time and did the job fine. Based on previous battery replacement projects, I thought the back of the phone would have to be pried out of attachment fittings on the phone body, but in fact it was mostly held on with glue, so heating and alcohol along with suction as described on this site are the way to go. Also you should purchase the OEM double sticky tape to reassemble the device nicely after the battery replacement.
このアンサーは役に立ちましたか?
Great suggestion. We have a few ceramic plates to protect surfaces from hot pots. I will heat one up on my griddle, 140℉ as a starting point, and work from there.
Thanks.
過去 24時間: 8
過去 7 日: 42
過去 30 日: 222
今までの合計 10,327
3 件のコメント
Thanks and also do i absolutely need an iOpener Or anything to do most repairs
Zac Cobos さんによる
Here is a video on using a heating pad as an iopener - https://www.youtube.com/watch?v=ZIrmxkX8...
Sebastian Edinger さんによる
https://www.amazon.com/dp/B00AZ72MAE/?th... is a larger option, It may take longer in the Microwave.
Joshua Lopez さんによる
