学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
If your Cosori TurboBlaze is making extremely loud noises that don't seem to be normal, follow this troubleshooting guide.
Loose Parts
- Unplug the fryer and examine it for any loose screws or components.
- Tighten any loose screws on the body or the basket.
Basket Obstruction
- Make certain that there’s no food or debris stuck in the basket or on the heating element that could cause rattling or banging sounds.
- Clean the basket thoroughly.
Improper Placement
- Ensure the air fryer is on a flat, stable surface. If the surface is uneven, the fryer may vibrate more than usual. Adjust its position accordingly.
Damaged Heating Element
- Inspect the heating element for any visible damage. If it appears bent or broken, it could cause unusual noises.
Non-optimal External Environment
- If using the air fryer on a surface that amplifies sound like metal or glass, try moving it to a softer surface like a countertop.
Faulty Fan
- The fan might be malfunctioning or obstructed.
- Unplug the fryer and check if the fan is clear of obstructions.
- If it appears damaged, it may need replacement.
Control Panel Failure
If the fan is not the core cause of your unit’s loud noise, then it is most likely due to the control panel.
- Repair and/or replace the control panel
0 件のコメント
