メインコンテンツにスキップ
Asus Zenfone 2 Teardown
英語
日本語
手順 2を翻訳中
手順2
Asus Zenfone 2 Teardown, Removing the battery: 手順 0、 3の画像 1 Asus Zenfone 2 Teardown, Removing the battery: 手順 0、 3の画像 2 Asus Zenfone 2 Teardown, Removing the battery: 手順 0、 3の画像 3
  • The battery connector is the connector at the right of the motherboard. Above the battery, there is a bridge connector which connects the mainboard with the sub board at the bottom. So remove both the cables. There is a slight adhesive below the battery. Cut through it with a plastic spudger and it will come out.
  • The sub board has the antenna terminals also and prior to removing the battery, the antenna cable needs to be removed as well. Gently disconnect the coaxial cable from both the motherboard and the sub board.
ここに翻訳を挿入する
ここに翻訳を挿入する
クリエイティブコモンズのオープンソース著作権のもと、あなたの投稿は著作権の対象となります
