メインコンテンツにスキップ
Nokia 1208 Mobile Phone Teardown
英語
日本語
手順 5を翻訳中
手順5
画像がありません
Display Housing Disassembly
  • When you take the display assembly and you flip it over with the display facing the table, you would see something like showen in the picture.
  • First, you need to remove the antenna housing from the unit, this is very easy to lift away from the display assembly as it is just slightly holding with a very little amound of glue. The antenna housing is the lila part showen in the picture, the antenna housing also houses the polyphonic speaker, you can remove that speaker also to change it.
  • You can remove this speaker with you're Torckx T6 screwdriver, its just held in with glue, its easy to lift it out of its casing.
ここに翻訳を挿入する
ここに翻訳を挿入する
ここに翻訳を挿入する
クリエイティブコモンズのオープンソース著作権のもと、あなたの投稿は著作権の対象となります
