手順 4を翻訳中
手順4
Removing each screw
Now take you're screwdriver, and remove those 6 screws you did see in the previous step.
Be carefull when you remove the last screw, hold the display assembly in the unit with a finger.
Now you can take out the entire display assembly that is attached to the main board.
I take you through the display assembly in the next step, because in the shell that houses the entire display assembly, you see a piece with 2 golden feet on it.
That is the microphone, and can be replaced with any microphone of the same type
Lets go to the next step
クリエイティブコモンズのオープンソース著作権のもと、あなたの投稿は著作権の対象となります。
