手順 2を翻訳中
手順2
Removing the battery
The battery will be glued to the PCB with double sided tape
Use your finger or a plastic spudger to carefully peal it off. The adhesive is not strong
You will have to desolder the leads to replace the battery
Start by desoldering the Ground lead
After isolating the Ground lead with a piece of tape, desolder the positive lead
The battery is made up of two 802540 lipos wired in parallel
クリエイティブコモンズのオープンソース著作権のもと、あなたの投稿は著作権の対象となります。
