メインコンテンツにスキップ
この分解は修理ガイドでは ありません。 お持ちのTile Stickerを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Tile Sticker Teardown, Tile Sticker Teardown: 手順 1、 1の画像 1
    • Use a spudger or flathead screwdriver to remove the outer ring
    • I removed the rubber button cover as well, but this is not necessary.
  2. Tile Sticker Teardown: 手順 2、 1の画像 1
    • Use a flathead screwdriver to pry the two halves of the case apart from each other
    • The technique I used is to find a small hole in the casing and use a very small flathead screwdriver with upward/downward force.
  3. Tile Sticker Teardown: 手順 3、 1の画像 1
    • Pull the electronics out of the casing.
  4. Tile Sticker Teardown: 手順 4、 1の画像 1
    • At the bottom is the power source - A soldered-in CR2032 battery.
  5. Tile Sticker Teardown: 手順 5、 1の画像 1
    • Hidden away in the top casing is a piezoelectric speaker.
  6. Tile Sticker Teardown: 手順 6、 1の画像 1
    • The main chips:
    • 240 C29
    • N(RF)52810 CAAAD0 1928AE
作成者
1人の作成者と共同作成されました。
Andrew S
メンバー登録日: 07/30/21
14,993 ポイント
8のガイドは作成済み
7 件のコメント
I’m glad I was not the only one who tried this, but you had much more success than me. We used to use ours for the remote to the TV which gets lost often and then the battery died and I refused to believe it was not user replaceable. Unfortunately I didn’t have much luck actually getting past step 1 since the two halves staunchly refused to come apart. So I murdered it in frustration and threw it in the bin.
Alisha C - 返信
Yep, mine lasted a little less than 2 years. The key to getting the two casing halves apart is to use a really small flathead screwdriver and put it in one of the holes in the casing, then start pushing downwards.
Andrew S -
So I got it open, desoldered the battery, resoldered a new one - and it turns on and beeps with a double tap… doesn’t ack its location, can’t be dinged from the app… can’t activate it because it says it’s already activated (duh) - but it’s been off for > 760 days according to Tile. Pretty sure they have a “drop dead” condition or some ultimate expiration date on the ones with soldered batteries (this forcing you to get new ones). AirTags for me from now on (I just wish they were louder)
Dave Miller - 返信
Scratch that! After repeatedly clicking - it’s now working again… huzzah!
Dave Miller - 返信
Glad to hear you had success in replacing the battery inside your Tile Sticker!
Andrew S -
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 41
過去 30 日: 159
今までの合計 8,282
