メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのMy First Sony Cassette-Corder TCM-4500を修理する際は、iFixitの修理ガイドをご利用ください。
  1. My First Sony Cassette-Corder Teardown, My First Sony Cassette-Corder Teardown: 手順 1、 3の画像 1 My First Sony Cassette-Corder Teardown, My First Sony Cassette-Corder Teardown: 手順 1、 3の画像 2 My First Sony Cassette-Corder Teardown, My First Sony Cassette-Corder Teardown: 手順 1、 3の画像 3
    • Here we have a 'my first Sony' cassette player with a microphone
    • It can even take a second microphone, sold seperately of course
    • Main microphone plug
    • Secondary Microphone plug
  2. My First Sony Cassette-Corder Teardown: 手順 2、 3の画像 1 My First Sony Cassette-Corder Teardown: 手順 2、 3の画像 2 My First Sony Cassette-Corder Teardown: 手順 2、 3の画像 3
    • This model uses four C-cell batteries, these have been in here since I was 10, hmmm... wonder if there's any juice left?
    • Time to take the batteries out
    • Push down at one end of each row of batteries towards the spring
    • With the tension released pull out on the battery until it comes out
    • Repeat until all four are removed
    • Thumbs up to Sony for providing nice visual instructions for those kiddies
  3. My First Sony Cassette-Corder Teardown: 手順 3、 2の画像 1 My First Sony Cassette-Corder Teardown: 手順 3、 2の画像 2
    • To remove the red back cover you need to remove six screws placed around the border of the cover. Note! The bottom 2 screws are longer than the other 4. These 2 are 35mm long whilst the other 4 are only 30mm long. Don't mix them up !
    • And voilà! Now we have a nice view of all the internal components
  4. My First Sony Cassette-Corder Teardown: 手順 4、 2の画像 1 My First Sony Cassette-Corder Teardown: 手順 4、 2の画像 2
    • Remove one screw to take off the rear part of the carrying handle
    • We also gain access to the rubber microphone holder
  5. My First Sony Cassette-Corder Teardown: 手順 5、 3の画像 1 My First Sony Cassette-Corder Teardown: 手順 5、 3の画像 2 My First Sony Cassette-Corder Teardown: 手順 5、 3の画像 3
    • To remove the speaker first you'll need to get some slack on the wire, do this by pulling it out of a plastic holder thing
    • Proceed to to lift up the blue chassis and remove the four screws holding the speaker down
    • These screws also hold the yellow speaker grill to the front
  6. My First Sony Cassette-Corder Teardown: 手順 6、 1の画像 1
    • It was a bit of a fight but I was able to pull the blue chassis out of the front piece of the red case
    • There were no fasteners holding them together
  7. My First Sony Cassette-Corder Teardown: 手順 7、 3の画像 1 My First Sony Cassette-Corder Teardown: 手順 7、 3の画像 2 My First Sony Cassette-Corder Teardown: 手順 7、 3の画像 3
    • Take out three screws to remove the main circuit board
    • Then unplug four sockets attached to the circuit board
    • And here we have the only circuit board in this device, don't see any big processors on it, I guess I can't turn it into a super computer :(
  8. My First Sony Cassette-Corder Teardown: 手順 8、 2の画像 1 My First Sony Cassette-Corder Teardown: 手順 8、 2の画像 2
    • After unplugging the circuit board we can completely remove the speaker
    • It packs a whopping 3 1/2 inch speaker
  9. My First Sony Cassette-Corder Teardown: 手順 9、 3の画像 1 My First Sony Cassette-Corder Teardown: 手順 9、 3の画像 2 My First Sony Cassette-Corder Teardown: 手順 9、 3の画像 3
    • Remove four screws to loosen the tape drive chassis
    • Then pull up and back to take the chassis out
    • With the tape drive chassis on its own we can look at Sony's weird button system, we also have the blue chassis with no components on it
  10. My First Sony Cassette-Corder Teardown: 手順 10、 1の画像 1
    • Take out two screws to remove the tape reader/writer
  11. My First Sony Cassette-Corder Teardown: 手順 11、 3の画像 1 My First Sony Cassette-Corder Teardown: 手順 11、 3の画像 2 My First Sony Cassette-Corder Teardown: 手順 11、 3の画像 3
    • To take the microphone apart just pull very hard on the red handle and it will come out, its held on by two tabs
    • Take off the yellow cover by wedging a flathead screwdriver in the crack and prying it off
    • Now we can look at a little microphone, and surprisingly it even has its own windscreen
  12. My First Sony Cassette-Corder Teardown: 手順 12、 1の画像 1
    • So here we have it all disassembled, and THERE WERE NO 'WARRANTY VOID' STICKERS ANYWHERE!!!
作成者
5人の作成者と共同で作成されました。
Harry333
メンバー登録日: 10/22/09
14 ポイント
1ガイドが承認済み
2 件のコメント
Do you know where I can find belts for this device? I need both belts new.
Florian Neiss - 返信
Try to look if you can replace it with kind of mixed belt pack : https://www.ebay.fr/itm/Universel-50-Mix...
François Opter -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 41
今までの合計 10,507
