分解
この分解は修理ガイドでは ありません。 お持ちのMacBook Unibody Model A1278を修理する際は、iFixitの修理ガイドをご利用ください。
The Unibody MacBook released in Late 2008 is one of the last Mac Notebooks to feature a "user replaceable battery".
Apple removed this feature in mid 2009 when they discontinued the Late 2008 Aluminium MacBook and introduced the 13" MacBook Pro with it's larger 58 Wh battery and its higher 1000 cycle rating for the battery.
With the plastic covers removed it's now time to get the battery pack out of its casing. However there is still on plastic piece glued to the aluminum casing which we have to remove first.
Insert a metal spudger in-between the plastic piece and the aluminium casing on the left side.
Be careful when working with metal objects near a battery pack. Shorting out the battery terminals can lead to a fire.
The pack is now disassembled.
Be careful not to puncture or damage the cells as this could lead to a fire.
ご自身のサイト/フォーラムに小さなウィジェットとしてこのガイドを埋め込むには、サイズを選択し下のコードをコピーしてください。
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 1,017
