メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのLinksys BEFSR41を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Linksys BEFSR41 Teardown, Linksys BEFSR41 Teardown: 手順 1、 1の画像 1
    • Top down view of the device.
  2. Linksys BEFSR41 Teardown: 手順 2、 1の画像 1
    • There actually aren't any screws or notches under the rubber feet on this model. A little force is all that's needed to pull off the front blue panel. (The front is held on by a recess/notch on each side)
  3. Linksys BEFSR41 Teardown: 手順 3、 1の画像 1
    • Once the front blue panel is off, the top panel slides back and then comes off easily (it's connected to the bottom panel by two plastic notches).
  4. Linksys BEFSR41 Teardown: 手順 4、 1の画像 1
    • Remove one small Philips screw from the logic board so you can remove the bottom panel.
  5. Linksys BEFSR41 Teardown: 手順 5、 1の画像 1
    • After removing the single screw and sliding off the bottom panel, all that is left is the main circuit board.
    • Main Components
    • Barrel-plug power connection / CAT5 / Reset button
    • Power Control
    • Line-drivers (allow CAT5 cables to carry data for 100m)
    • RAM (2Mb) (Stores MAC tables, etc)
    • KS8695 ARM922 (ARM Core, 5 switchboards, tcp/ip/udp packet interface)
    • RAM (1Mb )
    The 20PT1024X parts are Ethernet LAN magnetics from BothHandUSA, a common supplier of Ethernet magnetics (a term referring to an integrated monoblock containing per-wire-pair transformer and common-mode choke).
    Dan Wagner - 返信
  6. Linksys BEFSR41 Teardown: 手順 6、 1の画像 1
    • Bottom view of circuit board.
作成者
5人の作成者と共同で作成されました。
Ryan McLeod
メンバー登録日: 05/22/10
630 ポイント
2のガイドは作成済み
1件のガイドコメント
Thanks Ryan. Couldnt figure out how to get the case off until I checked here.
My BFSR41v2 teardown was identical so was able to replace the two 1000uf caps shown in step 5. The router gradually lost speed and finally quit altogether and wouldnt reset. Found the first cap had 5v AC across it and felt warm. The second cap was ok but replaced it anyway and the router is like new. BTW I was using it as a switch behind my wifi router to get more ports on my wired LAN.
Theres a good description of how to repurpose an old rouiter as a network switch on the How-to-geek site.
Cheers
Bill - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 14,692
